  1. Ok i am ripping my DVD's to HD and then using the DVD2AVI converter to make the 2 individual files. Then i want to make the file into AVI format. But when i use Virtualdub and the convert section of this website for reference, i starte the conversion and the program freezes. Before all this it said something about the program could lock up for having hacked codecs. Before all this i try using this webpage settings for the conversion and my virtualdub dont have some of those settings that this webpage has. I updated my virtualdub. I am trying to take my rips and put them in AVI format, so what can i do now ?
  2. I am sadened that nobody knows the answer.
    1. PLEASE post in correct forum. everything about dvd ripping in the dvd ripping forum , even if its converrrrrsion.
    2. please choose a better topic subject like problem converting to avi/divx with virtualdub
    3. please tell us the EXACT problem, what does you dont have as the guide has? exact what settings are you using.
  4. Making an AVI file should be no problem at all.
    FlaskMpeg is the easiest solution.
    It reads DVD *.ifo files. It outputs directly to AVI using the video and audio codec of your choice. It even supports subtitles.
    This way you only have to use 1 application to create you AVI file. A good way to start.
    There is a very nice flaskMpeg guide at the following link:
    http://www.digital-digest.com/nickyguides/
    Hope this helps. Have fun!
