Both myself and a friend have bought the Pioneer 106's to replace NEC's and we both are having the same problem that the 106 will write to +discs but nothing will read these discs not even the Pioneer that writes them but - discs are O.K. The + discs used are Traxdata and Infinity professional and so are not cheap inferior types --any Ideas anyone or should we return the drives and go back to NEC's which caused no problems at all.
i have burnt to some maxell +rewritables and had no probs with playback,dont know about plain writables though. i'me using pioneer 106d.
Hi PhilipL
I changed to the pioneer so I could write -discs as well as +discs.(one of my DVD players that will not read +discs)
As for software I have tried the New Nero 6,DVD Decrypter (wont evan recognise the writer)CopytoDVD and Recordnow Max, all right up to date.
And what I sold the NEC for and paid for the Pioneer was only a few Pounds differance and I thought it was worth it. -
A lot of people here seem to like the NEC ND-1300a dual format burner and it sells for only $155 in the states.
My 106 writes to + disks just fine -- and I play them on a wide variety of players. The fact that it won't play the disks it writes sends warning signals to me and makes me wonder if you're writing them properly (even if there was a misalignment you'd think it would play its own disks).
Try this: using Record Now (I think you said you had it) create a data disk and drag over the AUDIO_TS and VIDEO_TS folders (and those only). Make sure Record Now is set to verify the write. Then burn the disk. Assuming the disk burns and verifies without errors, open up PowerDVD (or WinDVD) and try playing that disk. I would be *amazed* if it didn't play (and if it didn't, then you have a dodgy drive, which I would swap for another).
I really love the 106 -- rock solid and even a better dual writer than my Sony A500 (which itself is no slouch)."Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang -
Well this is now so strange, after using ForceASPI to update-I can now write and read to all formats + and - discs,and the DVD player I have that would only read one type of disc now plays all + and - discs that I write.And DVD Decrypter recognises my Pioneer.Could it be as simple as the ASPI drivers that were the problem--who know's,not me.
Pioneer DVR-720H unfinalised VR mode discs
By MindF in forum DVD & Blu-ray RecordersReplies: 3Last Post: 17th Dec 2011, 03:06 -
Conflicting Claims: Can LG GGC-H20L write DL (50 GB) Blu-Ray discs or not?
By ambushed19 in forum Blu-ray RippingReplies: 14Last Post: 4th Apr 2010, 21:40 -
pioneer dv 470 and double layer discs
By SquireC in forum DVD & Blu-ray PlayersReplies: 2Last Post: 23rd Dec 2007, 05:09 -
What DVD-RW 2x discs can I use with my Pioneer DVR 3100
By longhaireddud in forum MediaReplies: 2Last Post: 30th May 2007, 12:14 -
Pioneer 420H - Can't Write Data Error
By cie3 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 23rd May 2007, 23:51
