hi all im using tmpegnc the latest version and im trying to make some dvd mpegs ready for burning etc. when i start tmpeg and the wizard loads up, i select pal and mpeg 1 layer 2 audio. when i go to step 2 i browse vie the video and select my mpeg and it should automatically fill in the audio!! but it doesnt!! so ive de mux'ed the the mpeg and loaded them manually in to tmpegnc and ok yeah it all joined fine and the reso was fine in the film but the sound was out of sync by about 20 secs. is there something im doing wrong? i need ur helps peeps
kinda new to this he he
seems nothing's wrong, but:
1) what kind of video are you giving to tmpgenc? (avi or mpg, codec, etc.)
2) when wizard pops up, in step 1 it has the choice for pal dvd and that's all, no choice for audio quality. this sounds a bit strange. -
im using mpegs. and yes there another option for mpeg1 mpegs 2 etc if u think about it there has to be cause ur making a dvd!!
kinda new to this he he -
not really....DVD is MPEG-2, NOT any other MPEG.Originally Posted by london
anywayz, what is your source .mpg?? is it VCD MPEG-1 or SVCD MPEG-2?
there are guides here to help you make the conversion, but you need to know what type of .mpg file you have first.
http://ness888.users.btopenworld.com/fromvcd2dvd.htm
https://www.videohelp.com/tmpgencdvd.htm -
The DVD specs support both mpeg-2 and mpeg-1
__________________________________________________ _________
PAL
Video:
Up to 9.8 Mbit/sec MPEG2 or up to 1.856 MBit/sec MPEG1 video
720 x 576 pixels MPEG2
704 x 576 pixels MPEG2
352 x 576 pixels MPEG2 (Same as the CVD Standard)
352 x 288 pixels MPEG2
352 x 288 pixels MPEG1 (Same as the VCD Standard)
25 frames/second
Audio:
Up to 8 audio tracks containing Dolby Digital, DTS, PCM(uncompressed audio), MPEG-1 Layer2. One audio track must have MPEG-1, DD or PCM Audio.
NTSC (NTSC Film)
Video:
720 x 480 pixels MPEG2
704 x 480 pixels MPEG2
352 x 480 pixels MPEG2 (Same as the CVD Standard)
352 x 240 pixels MPEG2
352 x 240 pixels MPEG1 (Same as the VCD Standard)
29,97 frames/second
24 frames/second with 3:2 pulldown (NTSC Film, this is only supported by MPEG2 video)
Audio:
Up to 8 audio tracks containing DD (Dolby Digital/AC3), DTS, PCM(uncompressed audio), MPEG-1 Layer2. One audio track must have DD or PCM Audio. -
my bad..forgot about MPEG-1 support...
however, will this VCD-DVD be as dvd player compatible as a DVD with MPEG-2...? -
Yes, as long as the DVD specs are followed. One thing to note the audio has to be 48khz not 44.1khz
want to create a boxset plz
By Lugs in forum EditingReplies: 5Last Post: 15th Nov 2011, 20:23 -
Two simple questions, plz help!
By UnD3R0aTh in forum DVD RippingReplies: 40Last Post: 4th Mar 2010, 11:47 -
help with megui error plz
By runLoganrun in forum Blu-ray RippingReplies: 1Last Post: 17th Feb 2010, 22:43 -
Help PLZ! subtitle problem.
By Ajimal in forum Newbie / General discussionsReplies: 2Last Post: 15th Feb 2010, 23:25 -
plz help
By sajjad223 in forum Video Streaming DownloadingReplies: 1Last Post: 4th May 2008, 11:12
