Hi, for the first time I've just been able to convert a .vob file to vcd format and burn it onto a cd.
I used OSEx to rip the .vob file. To convert the .vob to the right format I used the "VCD (PAL)" preset in ffmpegX (I had to use ffmpeg instead of mpeg2enc because of some problems) and then used Missing Media Burner to burn the .cue/.bin files onto CD's.
The VCD plays fine on my DVD player except for a problem with the audio sync. The weird thing is that the problem seems to variate, it's at it's worst at the beginning of the movie, then gets better to a point I'd be happy with but towards the end of the disk the problem becomes more pronounced again. At it's worst the video is about 2 sec infront of the audio.
Does anyone have any suggestions on how to fix this?
Results 1 to 1 of 1
AnonymousGuest
Newbie debugging sync audio video problem
By siocnarf in forum Video ConversionReplies: 3Last Post: 24th Apr 2012, 20:42 -
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
VirtualDub sync problem - Newbie question
By BobAchgill in forum Newbie / General discussionsReplies: 5Last Post: 10th Aug 2010, 15:58 -
Audio Sync Problem
By lwea2009 in forum Newbie / General discussionsReplies: 8Last Post: 30th May 2009, 15:19 -
Newbie trying to convert using WinFF - audio sync problems
By bogey44 in forum Video ConversionReplies: 1Last Post: 1st Mar 2009, 08:08
