Sorry i'm being such a ass hole but i need these things done, so if u can please accamedate me it woulds be good. thanks.
Results 31 to 58 of 58
I want to create subtitles for my home movies that show the date (and maybe time) of the video when enabled.
1. Is there an application that can extract date/time information from the DV AVI?
2. How would I go about keeping this sync'd with the video I would be editing (probably with Premiere)?
Xesdeeni -
Listern, i'm noit sure if i said something wrong but , i really need help with this, so if u can do what I suggested fine, if not i'll try to find something else on how to do it, thanks
hello, first off i wanted to thank you for
this guide, it is awesome, and very explanatory, excellent job. also i have a question. i downloaded the subtitle filter, but i dont know what file to place where. due to this, "SUBTITLER" is not one of the options in the "FILTER" menu on VirtualDub. can u please tell me what i have done wrong, and also how to correct it. thank you very much.
-skip2mylouWow! You got shocks, pegs... LUCKY! -
Have you installed the subtitler filter in your version yet?
Hello. -
@ skip2mylou
The file "filter_name.vdf" goes in the "plugins" folder under the VirtualDub main directory.
That should load the filter when VirtualDub is started. Failing that, you can manually load it for now until you sort it out...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Wow. This is what I've ben looking for, for a while now
I can't believe I missed this. For my home-movies and
other things I capture from Antenna
I can't wait to take a stab at this. I hope to report back
how this all goes.
Thanks in advance,
-vhelp -
FWIW.. only link that works for SSA is this one:
* Sub Station
I didn't realize it was 5mb plus. Anyways. I'll give your guide a go. I realize its over a year old
-vhelp -
I just tried this, (bar bones test) and it worked.
The guide is *rediculously easy* but I'd like to get a better
grip on how to place the text. I guess I'll have to play
around till I figure things out
Thanks to Tommyknocker (and my random surfing) I found
this guide
-vhelp -
well, honestly i dont know which one is for my version, pls assist.Originally Posted by TommyknockerWow! You got shocks, pegs... LUCKY!
please pardon me, but i don't see a file witha n extension with .vdf, pls assist.Originally Posted by daamon
thank you
YOU GUYS ROCK!!!
i found the right version, thanx to you guys, and i moved the .vdf file and all is fine, just in time for the HOLIDAYS, happy KWANZA everybody.Wow! You got shocks, pegs... LUCKY! -
Glad you got it sorted.
And I'd like to "have a happy KWANZA", if only I knew what it was
Carpe diem.
Need help with this problem.
I'm going to add english subtitle to an korea movie,
but the subtitles are in: for exampel hellu.sub
hellu.idx
how should I do??
Please explain step by step how to, just like you're explaining to an newbie.
I'm using Virtualdub 1.5.10 and SrtToSSA.
I only know how to add subtitle to an movie, only if there's one subtitle for exampel, casshern.srt. -
uh oh bad news
i finally got the subtitler in the menu however, how do add the subtitles. i mean i first clivked ADD for the .srt of the subtitle file, but i dont know what else to do from there to get it onto my movie, please help.
If you want to use .srt files, install the TextSub filter in Virtual Dub as well. Use the TextSub filter to display .srt or .sub subtitles.
Hello. -
well the problem is not the .srt or maybe it is. the thing is after i click SUBTITLER and i load the .ssa, i click preview and i dont see any subtitles on the screen. any advice??
i see the textsub.vdf but when i put it in the plug in folder on v-dub and start v-dub up, it gives an error prompt saying the .vdf file of textsub doesnt work. waht do i do. please help.
WOO HOO you guys rock!!
i guess nothing was wrong, i opened v-dub and in the filters, there it was textsub, so all is merry. thanks yall especially Tommyknocker, thanks!!
I'm having problems too... so I copied textsub.vdf to VD's plugins folder. When I opened VD, this error message came up: The application or DLL D:\Program Files\Virtual Dub\plugins\textsub.vdf is not a valid Windows image. Please check this against your installation diskette.
Thanks in advance...
A question that sometimes drives me hazy... Am I or the others crazy? -
yay! it works! thanks, and sorry for the total newbie question...
"A newbie in need is a newbie indeed." Glad it worked out for you.
Hello. -
When i play movie and subtitles in subsynch , movie, sound and subtitles are in sync. When i follow this guide to put the subs permanent in the movie as a divx , the result gives the sound out of sync! What do i have to do to get the sound also in sync?
Adding SSA subtitles to MP4 files
By ngngokkiu in forum SubtitleReplies: 19Last Post: 21st Feb 2012, 06:24 -
explorer.exe high memory usage while trying to load ass/ssa subtitles
By Nightroad in forum SubtitleReplies: 2Last Post: 17th Jan 2012, 18:36 -
Tool to convert SRT/SSA to Sony DVD Architect subtitles ?
By miguelos_net in forum SubtitleReplies: 4Last Post: 4th Dec 2011, 21:48 -
Low Sound Output After Adding .ssa to .avi
By edlimym in forum SubtitleReplies: 4Last Post: 12th May 2010, 08:02 -
error message when adding SSA. file to virtual dub
By fredsieg1937 in forum SubtitleReplies: 1Last Post: 24th Sep 2009, 21:53
