hey guys, plz help me on this, i am a newbie
I hv a 880MB file that i wanted to cut in half so i can fit it in 2 cds... i know i could go to the edit section and download the software.... i tried all of them...but i couldn't get any of them to cut/split up to the part that i wanted, cuz they are all demos...
wht can i do? how can i overcome this?
thnx!!!
You should be able to do this in TMPGEnc, even in trial mode. Look under File -> MPEG Tools -> Merge and Cut.
Just tried it on a VCD stream and it worked fine. Just 'Add' your file, double-click on the stream, and then select your Cut point... -
I tried TMPGEnc, yes, it would cut... but not to the part that i wanted....
after cutting i press "Run" then it always stops earlier than i wanted.... =(
i don't know wht to do....
or anyone has those software that i can borrow?
i m located in GTA/scar./markham -
Get DVtool it will cut your movie in exactly 2 equal parts and it keeps the audio/video perfectly in sync unlike some crap splitters out there
I have the same prob you have with TMPGEnc so i started using this DVtool and it works great -
I have found Womble pretty good for this. All other tools are too fiddly and take too much time
thnx all of u!!!
where can i get Womble, or DVtool??? where can i download it FREE? -
Hey,
Easy Video Splitter (shareware) and mpgscissors (free) will also cut videos. But they specifically will not work with VBR encoded source - i tried. Tmpgenc is pretty good for me because it can handle VBR but you mentioned that you can't get it to cut exactly where you want.
Cheers,
feeras
Splitting TS-file with tsMuxer creates lag in end file
By Prospero in forum EditingReplies: 6Last Post: 20th Apr 2011, 16:44 -
splitting wmv and mpg at time codes
By silverbullet69 in forum Newbie / General discussionsReplies: 4Last Post: 19th Mar 2009, 02:42 -
Converting and splitting 2GB MPG file
By mohalfares in forum Video ConversionReplies: 3Last Post: 2nd Sep 2008, 12:47 -
Splitting and Joining then Converting VOB > MPG > FLV
By deportu in forum Newbie / General discussionsReplies: 7Last Post: 12th Jun 2008, 21:32 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 17:52
