Hi. I've searched and I haven't seen any guides/topics on this subject. Hopefully one of the experts here can help me out.
I'm working on a movie and I'm currently in the stage of mixing the project in Dolby Digital 5.1 surround, with 6 WAV files to be converted into 5.1 AC3 using SoftEncode.
How exactly does an LFE track work? Would I put my sound effect (for example: gunshot, punch) in the LFE track? Do I put some kind of rumble sound effect on the track? What exactly would I do?
So far, I've tried just making a 5.0 track, and once in a blue moon, the effects are strong enough to bleed into the subwoofer. I'd like more of a punch on my soundtrack.
Thanks in advance,
J
Hello TenaciousJP.
While i have never tried this, it may be worth a try. I would author your 5 main audio tracks with all your sound efects in them, Then you could mix them all into a single wav file, apply a 40hz Low Pass filter and use the resulting low frequency wav as your LFE channel. -
Thanks, Deekkeed! I think I'll try that. It just might work.
If anyone else has any suggestions, feel free to share.
When you can't get the LFE to result in what you want...
By takearushfan in forum AudioReplies: 0Last Post: 15th Feb 2012, 22:44 -
Sony Vegas : How to restore LFE channel default setting?
By Bonie81 in forum Newbie / General discussionsReplies: 0Last Post: 22nd Jan 2011, 18:52 -
MPEG TS Streams missing LFE channel ?
By s1lenc0r in forum AudioReplies: 3Last Post: 17th Apr 2010, 09:20 -
NO LFE channel in TS transport streams ?
By s1lenc0r in forum Video ConversionReplies: 1Last Post: 17th Apr 2010, 07:02 -
How do TV channel make the weather newsman stand in front of the map?
By glieu in forum Newbie / General discussionsReplies: 14Last Post: 10th Jan 2008, 15:20
