Is there any other program like vcdEasy because i used this guide on this web about making Menu's using still images. i followed the instructions correctly but when i burned it and played on my dvd player it didnt show any the menu i created. i even pressed The Menu buton on my remote but nothing happnd. but the svcd works with menu's in my PowereDVD program on my pc.
SO why not my dvd player.
more info about your player here: https://www.videohelp.com/dvdplayers
if it works on your PC, perhaps your player doesn't like SVCD and/or menus
best bet is to try your SVCD on a friend's dvd player and see if menus show up there. -
poopyheads response is the first thing you should do. check to see if your dvd player actually plays SVCD and then try it on someone elses dvd player.
as far as an another program, www.dvd2svcd.org has an app that I think is great. Use it to convert everything from dvd's to avi's. -
My DVD player plays SVCD fine but as soon as you try to add menus and chapters it goes wildly out of synch. I just burn them without now and they play fine.
Fozzee
A program that does something similar to the Re-author function dvd shrink?
By Bruxo in forum DVD RippingReplies: 5Last Post: 5th Jun 2011, 05:57 -
Mac audio program similar to BeSweet?
By bgart13 in forum MacReplies: 2Last Post: 26th Jan 2011, 05:44 -
Newbie looking for a video editing program similar to Windows Movie Maker
By Anonymous74 in forum EditingReplies: 3Last Post: 18th Sep 2008, 01:48 -
4:3 to Letterbox (or Something Similar)
By christopheramos in forum Authoring (DVD)Replies: 2Last Post: 23rd Aug 2008, 02:57 -
Can someone recommend a freeware program similar to AOA dvd ripper?(youtube
By tecmobo34 in forum Newbie / General discussionsReplies: 2Last Post: 28th May 2007, 16:16
