I find DVD-R to be a good medium for recording audio since one disc can hold as much as six hours of program material. I am currently using a Panasonic standalone DVD recorder for this purpose. While the sound is adequate it suffers somewhat from the fact that audio is recorded in Dolby Digital, a format that uses compression. I was wondering if anybody knew of a standalone DVD recorder that can record audio as PCM files. PCM is a better sounding format than Dolby Digital since it is not compressed. I use the DVD recorder primarily to record radio programs.
Thanks for your help,
Joe
If you input RCA stereo (Left and Right) cables, then you should get PCM stereo.
PCM is only a stereo format while DD is a 5.1/6.1 format.
But yes, PCM is better for music.THIS has been an RVL123 production... -
Thanks for the reply. I believe Dolby Digital can be recorded as a stereo format also. For example, there are DVD-V titles, particularly music videos, that are playable as Dolby Digital stereo recordings only. I am using RCA stereo cables for recording purposes but have always been under the impression that the recording format was Dolby Digital. In fact, I don't think the Panasonic recorder is capable of recording in 5.1 or 6.1.
Thanks again,
Joe -
That was Dolby Stereo that you were listening to.Originally Posted by surfsup
I checked on the panasonic website and it seems that all the recording decks have Dolby Stereo (2-channel) recording.
Here's what I would do: Go to a store with a good return policy, Buy the unit you are interested in, See if the audio/video quality is acceptable, if it is keep it, if not return it. Sorry for that huge run-on :P .
Another thought would be to use a high-end CD-recorder. I know Yamaha made one that had a 30 GB (I think) hard drive and would record digitally. You can find it cheap on eBay since it was discontinued this past winter.
Hope this helps you!THIS has been an RVL123 production...
No sound from a PCM audio stream using DVDFab DVD to AVI file.
By loninappleton in forum AudioReplies: 8Last Post: 5th Dec 2011, 04:27 -
Authoring DVD with four subtitle tracks and PCM audio?
By bizzybody in forum Authoring (DVD)Replies: 7Last Post: 28th Feb 2010, 22:17 -
Audio options in DVD player, RAW or PCM?
By dzsoul in forum DVD & Blu-ray PlayersReplies: 0Last Post: 31st Dec 2009, 05:00 -
Problem with PCM Audio track when Burning DVD
By darnhs in forum DVD RippingReplies: 7Last Post: 11th Aug 2008, 21:07 -
audio PCM to MP2 while retaining DVD menus
By navels in forum Video ConversionReplies: 2Last Post: 20th May 2007, 15:51
