Hi
I have a movie that is 1.4 GB large.
1 - Should I try to fit it on one CD by compression (will it really be ok quality)
2 - If I should split the file, how do I do that?
Rgds
Henke
Any compression you do will degrade the quality, maybe a little or maybe alot. I'd say if it's already in MPG format, it's already compressed so compressing it more would really effect quality. I would rather split the file. There are several tools, but I use TMPGEnc. Look under 'MPEG Tools', it lets you select the starting and ending frames for each output file. Try to do it as close to the center as possible, so you'll have two roughly 700mb files.
Batch "file creation from a text file, Placed into a created directory
By Muther in forum ProgrammingReplies: 5Last Post: 24th Sep 2015, 18:29 -
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 18:28 -
changing ifo file names on same file ext of diff dvd files
By holliquinn in forum Newbie / General discussionsReplies: 2Last Post: 5th Jun 2008, 05:02 -
question about converting flv file to regular avi type of file
By jimdagys in forum Video ConversionReplies: 4Last Post: 28th Nov 2007, 11:39 -
Converting VOB file to MP4 file. Video is perfect, audio is nonexistent.
By jdfrosty in forum ffmpegX general discussionReplies: 6Last Post: 17th Jul 2007, 18:31
