I have encoded lots of SVCD's to DVD yet I am having a few problems on a few DVD players not reading the disk correctly and the picture either comes out bad or green lines along the screen and I know what the problem is and wondered if anyone know of a solution to it.
Basically after converting SVCD to DVD the DVD still thinks it's a SVCD on a DVD disk and so I wondered if there was anyway I can make it a true DVD disk after converting from a SVCD to DVD.
If anyone has any help or comments on this please help
Why are the best things things in life cost the most money?
Who stole the rest of my Signature, Own up, it was you, yeah you, thats it I am gonna come over there and .......... -
I am gonna try the last link you gave me, I hope it works, cheers m8
If anyone else has any links that I can convert SVCD to (true)DVD then let me know, I am willing to try anythingWhy are the best things things in life cost the most money?
I have used this process to convert in excess of 60 films, and have never had any problem, so far, I hope you find it useful
Ness -
Just to add to this, I have used the guide and it does indeed make a true DVD film, but I do 2 questions.
1. If a film is 3 SVCD's and I convert using Main Concept Encoder the film always seems to be bigger than 4.7gig more like 6gigish, how do I get it down to fit on a DVD without shrinking it using something like DVD2one or InstantCopy?
2. There is one setting I am not to sure about and wondered if anyone can explain it to me, I am not sure if this helps in question 1: In Main Concept Encoder the bit where it says "Depending on the output size of your mpeg, you may not need to decrease/increase the bitrate, and you could leave it as variable, if the mpeg is larger than 1.3gb I would suggest selecting a constantbitrate of approx 4500, as below, select ok, and return to main window."
JLRWhy are the best things things in life cost the most money?
come to think about it I have come accross a problem, some of the films I encode are well out of sync and thats TMPGEnc that is causing that when I join them together, I doubt it's the mpeg encoder, so is there a way to encode and not have the films out of sync
Help with svcd 2 dvd
By tastybaker in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 11th Aug 2010, 09:30 -
Svcd 2 dvd
By GeordieDave in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Feb 2010, 10:05 -
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 16:56 -
Can a SVCD video file be burned on to a DVD and played in a DVD player?
By dvdnewbie64 in forum Newbie / General discussionsReplies: 9Last Post: 17th Apr 2008, 20:44 -
How to burn a SVCD onto a DVD?
By php111 in forum Authoring (VCD/SVCD)Replies: 9Last Post: 16th Oct 2007, 02:32
