  1. gzngzr
    Guest
    Input #0, mov, from '/Volumes/GzRvs120/Capture Scratch/108/108.1.3':
    Stream #0.0: Video: dvvideo, 720x480, 16.20 fps, 800 kb/s
    Stream #0.1: Audio: pcm_s16be, 48000 Hz, stereo, 1536 kb/s
    Output #0, yuv4mpegpipe, to 'pipe:':
    Stream #0.0: Video: rawvideo, yuv420p, 720x480, 29.97 fps, q=2-31, 200 kb/s
    Stream mapping:
    Stream #0.0 -> #0.0
    Press [q] to stop encoding
    : command not found[InternetShortcut]
    RESET 0 8 err:0
    CODECID 31 31 sowt
    Output #0, mp2, to '/Volumes/GzRvs120/Capture Scratch/108/video.xx.mp2':
    Stream #0.0: Audio: mp2, 48000 Hz, stereo, 128 kb/s
    Stream mapping:
    Stream #0.1 -> #0.0
    sh: line 1: 707 Segmentation fault /Volumes/ffmpegX0.0.7c/ffmpegX.app//Contents/Resources/ffmpeg -i /Volumes/GzRvs120/Capture\ Scratch/108/108.1.3 -y -vn -f mp2 -acodec mp2 -ab 128 -ar 48000 -ac 2 -map 1.1:0.0 /Volumes/GzRvs120/Capture\ Scratch/108/video.xx.mp2
    the video doesn't encode.
    and why does it read stream #0.0 as 16.20 fps when it is and plays at 29.97?
    audio comes out as .mp2 instead of ac3.
    I'm new to this be. want to buy but make it work, please.
    thanks.
  2. Add a .mov extension to your input file before encoding the video. Use A-Pack to create the AC3 stream.
