I have just bought a Pioneer 106 DVD writer and am very happy with it... but for some reason... Nero wont see it.
Does anyone know why as Ilike Nero but now cannot use it.
Cheers for any help!
Comfy
get the latest version of nero . 6.0.0.9
(how can you be happy with it if you can't use it?) -
I doubt that's the problem - I bet he's using a version that came with a different drive... or a copy of dubious source.
If you bought say a Yamaha CD-R drive and Nero came with that, it's probably locked to Yamaha, and thus will NOT work with the Pioneer due to licensing issues.
When you've got that issue sorted, don't forget to change the drop down box from CD to DVD and to change the recorder option from the menu to select which drive you want to use.
Help with Pioneer DVD Writer DVR-112D and Nero
By tdoran70 in forum DVD & Blu-ray WritersReplies: 6Last Post: 1st Sep 2008, 17:23 -
DVD Writer won't write
By hcs in forum DVD & Blu-ray WritersReplies: 4Last Post: 21st Nov 2007, 05:46 -
Nero won't burn video DVD
By solo_voyager in forum Newbie / General discussionsReplies: 3Last Post: 13th Nov 2007, 22:06 -
Problem with burning using my LG writer won't go away
By pwil30 in forum DVD & Blu-ray WritersReplies: 7Last Post: 16th Jul 2007, 11:12
