I have 3 separate folders with 3 different bin & cue files. What software and how would you merge 3 separate bin & cue files to have one complete file for burning?![]()
Results 1 to 10 of 10
Serge
I'll have to make many assumtions, since theres not alot of info there.
1) You have 3 SVCD bin/cues
2) Combnined they are under 800mb
Use VCDGear to extract the mpegs to your hard drive.
Use VCDEasy to create a new bin/cue with all 3 mpegs
Burn the new bin/cueEjoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
Thanks for you relply. The bin and cue files are not no disk, they are actually on my harddrive so there are no mpegs to extract. Would you still use VCD Gear and VCD East to compine them? Please take a look at the image. Thank you.
http://www.sergeeustache.com/Stuff/Bin.jpgSerge -
I Thought VCDGear would extract mpegs from a bin/cue.
if it wont, then use DeamonTools to mount the bin/cue and extract the mpegsEjoc's CVD Page:
DVD:
Capture:
bin/cue are image files, you can't combine them. You need to extract the mpegs and combine those. Use Deamon Tool to mount the image.
I have the software Deamon Tool. Are there any instructions on how to mount the drive and extract the mpegs.
Serge -
install "Deamon Tools"
reboot
click on the tools icon in your system tray and select mount image , pick image, mount
copy mpeg to your hard drive
end
but you could just use isobuster and extract mpeg ... -
Thank for your help. I was able to extract the mpegs. I have one final question. How would you actually merge the mpegs?
Serge -
TMPGEnc, mpeg tools, merge and cut. Dont be surprised if they do not join correctly though. Mpeg-2 files are notoriously difficult to join correctly.
I'll beg the question: Why bother to merge them? If your going to Author a DVD, you don't need to.
To Be, Or, Not To Be, That, Is The Gazorgan Plan
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
extracting the bin/cue from .oo1,.002 etc files
By belwas in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2010, 00:59 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 09:11 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29
