I began to encode an SVCD with TMPGEnc, and noticed the CPU level was between 93 and 100%. Is this normal? I have a Dell Dimension XPS T500 with pentium III, 500 mHz, and am running the program on a 40gig hard drive. Also, does this mean it probably wouldn't be worth it to try making a DVD on this computer without upgrading?
Yes, 100% CPU use is normal. You could make DVDs on it, it would just take a long time to encode.
yes...especially with such a low clockspeed (i.e. 500 MHz), tmpgenc will be using most of it. even so, the encode times prolly will take longer.
there's almost a linear inverse relationship between CPU power and encode time. if you double your CPU power, you will basically reduce the encode time by half.
ffmpeg CPU usage
By diprotic in forum Video ConversionReplies: 13Last Post: 19th Apr 2015, 14:40 -
how to limit cpu usage for program
By deejay.2001 in forum ComputerReplies: 8Last Post: 17th Jul 2008, 20:27 -
100% CPU Usage while outputing from TMPGEnc DVD Author
By lj01 in forum Newbie / General discussionsReplies: 3Last Post: 21st May 2008, 10:09 -
CPU usage goes to 100%
By Tbag in forum ComputerReplies: 21Last Post: 18th Jan 2008, 09:59 -
ffmpeg only 50% CPU usage in Windows
By ChrisStanleyCCTV in forum Video ConversionReplies: 6Last Post: 12th Nov 2007, 17:38
