I have just recently got a digital camera have both the above programs I am looking fo guides on either of the above and to see if anybody has suggestions which one to use first as I am mere novice, or do i use both one for capturing and other for editing.
Help or links to easy to follow guides much appreciated, I will be doing my dvds in the PAL format.
thanks
sheppy
Hi there,
I think Studio 8 is your best bet out of the two. Prem is a very big learning curve. Have seen Studio in action on mates computer and it is very good at Effects. Very easy! Mind you, it won't let you use the pro Effects until you unlock themKeep going till you get it right!!! -
I first attempted to learn video editing by using Studio 8 but had many software problems. After downloading the free trial of Premier, I switched and never touched Studio again. Yes, the learning curve is somewhat steeper but well worth the results.
Newbie - Adobe Premiere/Computer Horsepower
By rgibson in forum Newbie / General discussionsReplies: 8Last Post: 11th Jan 2011, 08:13 -
no sound when i captured from dv in adobe prem cs. even hd didn't work
By cannibalcam in forum AudioReplies: 7Last Post: 5th Mar 2008, 07:07 -
Newbie looking for easy guides, links, and general information
By TazDevil in forum Newbie / General discussionsReplies: 2Last Post: 1st Sep 2007, 11:53 -
Adobe Prem 2.0
By caeK in forum EditingReplies: 1Last Post: 1st Jul 2007, 11:21 -
Pinnacle Studio Plus Titanium 10.5 versus Adobe Premiere Elements
By bowmah in forum Newbie / General discussionsReplies: 0Last Post: 13th Jun 2007, 16:48
