  1. I've tried to jion 3SVCD files in TMPGEnc two times now and the audio synce is off were the second file is jioned. The second time I made sure that the type was mpeg-2 super Video cd.
    I have looked through all the edit and join areas and can't seem to get the other programs to even work.
    Any ideas as what i'm doing wrong or how it get the audio synce correct...TIA
    Apr 2002
    The State of Frustration
    Choose your poison.
    Hello.
  3. get the cds in .bin files....cdrwin style
    get svcd2dvdmpg
    load the .bin
    export to .mpg do not patch header
    do all files
    join with tmpgenc
    ya can even trim the overlaps while ya join
    just highlight in the join dialogue and edit
    enjoy
  4. Thanks that work good but one problem it writes it to pal format and I can't seem to find a way to change it . I'm using TMPCEnc dvd author and it won't write it in Pal format....TIA
  5. Your sync problem may just be your version of TMPGEnc. If you go to their website and check the history make sure you do not have the version of TMPGEnc that caused vid/aud to go out of sync when using open GOPs.
    Apr 2003
    my computer, where else?
    were you using tmpgenc 2.59? that's the one with the problems.
