I used DVD Decrypter to backup a chapter with just the AC3 5.1 audio.
VOBEdit to Demux.
When I tried to drop the video and audio into ReelDVD it said the audio is a format it doesn't use. I was under the impression it did. I also tried with 2 Channel AC3 and it won't accept it either. There is no PCM on the DVD I want to backup.
Am I doing something wrong or does ReelDVD not accept AC3? If so, which authoring program can you suggest that will use AC3. I can't afford something like Scenarist and really don't want to go through that kind of learning curve anyway. Any suggestions?
........Gord
Outside a dog a book is man's best friend. Inside a dog it's too dark to read.
------------ Groucho Marx -
DVD-Lab
30 day free trial in case you don't like it.
Edit: By the way, you can import vob's directly. No need to demux. -
I guess I should have mentioned that I've been trying DVD-Lab and have had problems with it, as well. When I try compiling the DVD I get a message that says cannot packetize audio stream. I don't know for sure what that means but it keeps happening and when I burn the DVD there is no audio present. I've tried both by letting DVD-Lab to the demux step and by using VOBedit do demux the VOB file and then drop the discreet audio and video files into DVD-Lab and neither one of the steps works.
Any thoughts on what this is all about?
........GordOutside a dog a book is man's best friend. Inside a dog it's too dark to read.
Try 1.2.2 beta. http://www.mediachance.com/dvdlab/history.html
- fix for ES audio compile problem (1.2.2)
http://www.mediachance.com/forum.htm
To be honest, I don't reauthor backups. I do create ac3 audio for capture compilations with softEncode, and I've never had a problem. I have 1.2.2 installed.
Authoring program for sub/idx ?
By Capum in forum Newbie / General discussionsReplies: 5Last Post: 6th Dec 2010, 16:15 -
Which dvd authoring program could I use...
By sagat93 in forum Authoring (DVD)Replies: 5Last Post: 14th Oct 2009, 21:43 -
which dvd-authoring program is better?
By siluet in forum Authoring (DVD)Replies: 9Last Post: 8th Oct 2008, 14:25 -
The Best DVD Authoring program
By Random490 in forum Authoring (DVD)Replies: 6Last Post: 12th Dec 2007, 04:10 -
Authoring an NTSC program
By spliffy in forum Authoring (DVD)Replies: 6Last Post: 7th Sep 2007, 16:19
