i have some bad frames to delete. i use vdubmp3.exe to do this. now i have this file badframes.log and when i view it,it says it needs America.exe to locate it. where can i get this america.exe or am i not doing it right. need your help.
oops, Your associations have been messed up.
Your "Notepad" should be associated with txt files, and this log is a text file.
highlight the file, hold shift key down and click your right hand mouse and select "Open With" scroll down the list and find notepad, Check the box and click OK
All future *.log files will now open in notepad
i'll do that and thank you very much for your help. i always see your name in almost everything here helping others too. i appreciate it.
Can not log onto PC
By Noahtuck in forum ComputerReplies: 19Last Post: 12th Dec 2009, 22:35 -
Log in?
By alintatoc in forum ComputerReplies: 10Last Post: 5th May 2009, 02:04 -
Log Me In
By Lucifers_Ghost in forum ComputerReplies: 3Last Post: 6th Jun 2008, 08:02 -
Log in
By MintyJ in forum ffmpegX general discussionReplies: 3Last Post: 15th Mar 2008, 18:18 -
Fixing badframes with Avisynth
By demonwarrior in forum Newbie / General discussionsReplies: 6Last Post: 27th Dec 2007, 03:26
