  1. i dont want to turn them off (i'm registered to tons of message boards and would like to stay logged in) but I want to prevent these that appear most often in AdAware as Tracking cookies.
  2. I can solve one of your problems at least.
    If you go to the Double Click website (www.doubleclick.net maybe .com) they can issue you a cookie that tells it's tracking banners not to record/issue you tracking cookies.
    I even believe Ad Aware can tell the difference between a normal doubleclick.net cookie and they non-tracking one.
    You could also up your privacy settings in the Internet Explorer Options menu from 'Medium' (default) to 'Medium High'.
  3. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    _____________@hotgaylovers[1].txt
    :P
  4. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    true - I run Ad Aware all the time, it's never interfered with this board's cookies or any other board where I log in automatically.
    (although for some reason, all of a sudden my work computer won't take a damn cookie for this site, and I have to log in manually every time! balls!)
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
  5. but can i turn off cookies and still have all my message board login and passwords remembered?
  6. I believe I just found a method (for IE6 anyway).
    1) Go to Tools -> Options -> Privacy
    2) Now slide the button all the way upto 'Block all Cookies'.
    3) Down the bottom of that window will be an area titled 'Web Sites' and it allows you to over ride the options for individual web sites. Click on 'Edit' and add the URL's of your forum sites and click 'Allow'.
    That should then make IE do want you want it to.
