hi, every time i try to author a dvd with this there is allways something wrong. 1 the size is "too big" even thought its 4 gigs and can be writen with ulead. 2. volume does not exist or something like that, what does that mean ?
oh never mond...i figured it out myself...now i am having trouble when i try to create a disc...when it startd multiplexing a windows box pops up and says it encountered an error send report errors and dont send...ever time this happens does n e 1 know why
recreate the same EXACT problem using everyything, pictures, video streams, adurio streams, etc. When the error windows pops up, write it down Exactly as it is in the window. Then go over the Sonic Solutions DVDit Forum, and search for the error code. MOst of the time that a new user has gooten a error code, other have as well. So far all my error have been established and resolved with simple solutions. Keep in mind, a key downfall of DVDit is that all the video and audio has to be EXACTLY the same externally and internally (frame rate, color scheme, codecs, headers etc). You can not have a AC3 and a WAV audio in the project, nor can you have a MPG and a M2V or a M2V and a M1V. Just because DVDit supports all these files types does not mean you can mix them in the same project.
no...i tried that and it has no error...its a windows error because a windows box pos up
subtitles with DVDit 6 PRO
By jakewoodblues in forum Authoring (DVD)Replies: 2Last Post: 16th Apr 2010, 13:51 -
Replacement for DVDit Pro HD 6.3 Final
By GrampaD in forum Authoring (Blu-ray)Replies: 2Last Post: 11th Oct 2009, 11:04 -
Subtitle Sync Problems in DVDit Pro
By aquaorbis in forum SubtitleReplies: 0Last Post: 5th May 2009, 22:40 -
Has anyone used Sonic Scenarist or DVDit pro HD?
By jbandy1 in forum Authoring (Blu-ray)Replies: 16Last Post: 18th Feb 2009, 01:08 -
DVDit Pro HD and Sript error in activation
By arturjose in forum Authoring (DVD)Replies: 1Last Post: 19th Nov 2007, 00:51
