  1. Member foaley77's Avatar
    Jan 2002
    Adelaide ,Australia
    Hi just wondering if anyone knows where are can find guides for copying dvd9 to 1 and 2 dvd-rs using these programs Tmpgenc ,Smartripper,DVD2AVI and Ulead movie factory
    Cheers
  2. Try looking on the left hand suide in the green print under HOW TO and select GUIDES...then search by those specific tools.
  3. @foaley77,
    you may wanna expand the amount of software tools you use.
    https://www.videohelp.com/forum/userguides/141024
