I jut ordered the TBC AVT 8710 to counter act the Macrosivion and other copyright stuff to use with my Panny DMR-E30. However, using the credit card transaction facility - at the end of it all i did not get any conformation notice that my peice will be sent and credit card details have been accepted. The website just took my details and that was it. Is this site legal or will I gave probs???
Further, once the TBC is received, how do I connect it to my recorder? Is it just between the DVD player and recorder or does another line have to go to the TV?
I just called the phone number on the website and ordered it that way. If worried , call them to make sure.
The VIDEO OUTPUT of your SOURCE goes to the VIDEO INPUT on the TBC then the VIDEO OUTPUT on the TBC goes to the VIDEO INPUT on your RECORDING device.
The audio should go straight from your SOURCE to your RECORDING device.
If you want to watch what you are recording then you can do that by hooking the OUTPUT of your RECORDING DEVICE (in this case a stand alone DVD recorder) to your TV.
Very simple.
One note though. If you use a 6 foot audio cord use two 3 foot video cords. Or if your audio cord is 12 foot then make sure you use two 6 foot video cords. This way the video and audio length are the same. The shorter the better though.
AG-1980: Vertical jitter with or without AVT-8710 TBC. Ideas?
By Mini-Me in forum Capturing and VCRReplies: 7Last Post: 4th Aug 2011, 10:31 -
TBC suggestions: TBC-1000, AVT-8710, ADVC-300, TV1-TBC, or TV1-TBC-GL
By m27315 in forum RestorationReplies: 16Last Post: 24th Mar 2010, 02:36 -
AVToolbox AVT-8710 TBC
By maeks84 in forum RestorationReplies: 3Last Post: 28th Apr 2008, 01:37 -
Help with AVT-8710 TBC
By Reniamatic in forum RestorationReplies: 2Last Post: 17th Sep 2007, 16:26 -
new here how do i setup tbc AVT-8710 Urgently
By effects in forum RestorationReplies: 7Last Post: 6th Jul 2007, 14:21
