From a link here on the forum, I downloaded MM 2.0 just to see how it compares to the MyDVD 4.0.4 I got with my Videoh DVD.
It downloaded fine, and opens fine, but when I click capture, it says it "cannot find the capture device..reinstall drivers".
Emuze site has no driver downloads that I can find, and the Videoh capture (USB 2.0) works fine w/ Sonic MyDVD, so I know the device works.
Any idea how to get MovieMill up and running?
Thanks from a new kid around here.
Alfer
Visit my Philips DVD Recorders discussion group HERE and my Home Theater site The Enormodome
Hope this isn't a useless response but I'll ASSUME you may not know this - just in an effort to help.
Did you press "Play" before attempting to capture? It's a tiny detail, but I have the VideoOh DVD w/ MovieMill and it will not recognise anything until you have a tape actually playing.
Until a tape is playing, you'll get the "no device found" message.
Hope that helps. If not, good luck anyway.
Looking for capture device, is this what I need?
By V Bot in forum Capturing and VCRReplies: 3Last Post: 21st Apr 2012, 09:16 -
Capture Device
By NMeade in forum Capturing and VCRReplies: 7Last Post: 24th Feb 2011, 17:23 -
"Cannot Find Caputure Device"
By SpydaMan in forum Capturing and VCRReplies: 2Last Post: 9th Sep 2010, 17:55 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 04:31 -
capture device for hd
By jjjamiem in forum Newbie / General discussionsReplies: 2Last Post: 8th Aug 2007, 14:30
