I am using dvd2avi version 1.74 and when i am done, tmpgenc does not read the .d2v file as a video source option. You have to select it under all files and it says that it is not supported and cannot be opened. Please help.
1) make sure the file DVD2AVI.vfp is in the same directory as your dvd2avi file.
2) when u run dvd2avi, make sure help->vfapi plug-in is checked
3) make sure that u DON'T -
oops, accidentally submitted w/o compeleting...anyways
3) make sure that u DON'T delete the vobs after u make the project file. the project file points to the EXACT location of the vobs...tempgenc will still need the original vobs as the video source to encode with...so DON'T EVEN MOVE the vobs.
Certain d2v file causing problems with MeGUI Avisynth Script Creator.
By Simcut in forum Newbie / General discussionsReplies: 5Last Post: 30th Jul 2012, 16:57 -
D2V Creator in MeGUI
By mysteryman26 in forum Newbie / General discussionsReplies: 2Last Post: 17th Mar 2011, 05:40 -
What does this .d2v parse tell me?
By fatcharlie in forum Newbie / General discussionsReplies: 54Last Post: 10th Mar 2011, 17:13 -
Syncing audio with d2v
By Norio in forum Video ConversionReplies: 8Last Post: 23rd May 2010, 01:07 -
Fix D2V tool??
By BIFFtheSTIFF in forum Video ConversionReplies: 1Last Post: 15th Jan 2009, 01:40
