I've been converting files to MPEG2 and authoring them to DVD. I'm burning them to DVD-Rs. What I notice is that when I play them back on my TV, the perimeter of the picture is slightly cut off. It's not extremely noticable, but if there is a way to fix the problem I would like to know. I am using TMPGEnc to convert to MPEG, and TMPGEnc DVD Author to author. Are there any settings that prevent this from happening, or is it just something inherent to TV playback?
You could add a mask to your video, or borders.
Hello. -
Yes. Look up "overscanning" in the glossary.Originally Posted by caimanWant my help? Ask here! (not via PM!)
So is this just something you guys live with? Or should I look into fixing it?Originally Posted by lordsmurf
I would add a border around it if I had it. It would not show up on the screen, and I would still get to see the entire image.
Hello. -
Ok, thanks guys. In TMPGEnce I used custom aspect ratio, and changed it slightly to create a border. Seems to be working. Hopefully this will get rid of the overscane wihout distorting the image (I used 690X460).
Edit something out of the picture ... Final cut/photoshop extended?
By perik in forum EditingReplies: 0Last Post: 29th Dec 2008, 10:27 -
Edges of video cut off when played on DVD player. HELP
By natrap in forum Authoring (DVD)Replies: 8Last Post: 21st Dec 2008, 23:23 -
Why are menu side edges cut off?
By terrypin in forum Authoring (DVD)Replies: 6Last Post: 16th Dec 2008, 08:18 -
swf to avi - last few frames of animation get cut in the avi - any solution
By perfection in forum Newbie / General discussionsReplies: 0Last Post: 5th Sep 2007, 09:01 -
Sides of picture cut off on TV after AVI to DVD
By HavoK041 in forum Newbie / General discussionsReplies: 1Last Post: 8th Aug 2007, 04:41
