I have several anime files that are dual audio .ogm files encoded with Xvid for the video and Ogg for both audios. I want to make SVCDs out of these and after MUCH searching, I can't find any information that matches what I need, I've found a bit using other types of audio, but not Ogg. I just can't put my finger on this one. When I use VirtualDubMod, I check the File Information, it give me:
Video - FourCC: XVID XviD MPEG-4 Codec (I have Keropi)
Audio - Tag: 0xFFFE, Not decodable EXTENSIBLE Compression Unknown
I have TMPG Full Version, and can get ANY other software I need, just fill me in on what. I really would like to make SVCDs out of these, I DON'T even want to use the 2nd audio, which is Japanese, I only want the English Dialogue.
Thanks for your time, I'm a noob here, sorry for such a long post.
Don't say your a noob, have some confidence in your skillz man, you will learn.
First of to begin with can you play your OGM files correctly...?
If you can't try this really excellent OGM player that installs the things necessary to play the OGM's correctly by clicking here
www.corecoded.com
When you can play your files correctly and are ready to convert your OGM to SVCD, or SVCD with Multiple audio tracks and selectable subtitles depending on your DVD Player check out my pretty easy to use guide by clicking here
https://www.videohelp.com/forum/userguides/170944.php
...if you have problems don't hesitate to reply back, and I will try my best to help you. Have some balls.
Check out my guide on converting .OGM format to an SVCD with Selectable Subtitles and Multiple Audio tracks.
https://www.videohelp.com/forum/userguides/170944.php -
Oh, I can make SVCD's like a mofo, I just can't past the XviD codec making my SVCD's backwards and upside down. ANY other codec I can deal with. I can play OGM's real well, I keep very up to date on codecs, I'm in #AnimeCorp. I have a Sampo DVD player, plays all my SVCD's perfectly, no glitches/hangups/out of sync. The only thing is still no matter how many different ways I try, no prog will let me convert any XviD encoded video into any that is right side up. I can make SVCD's, but they are all upside down even after conversion. If I try to view the mpeg2 after I encode it, it turns out fine on the PC, but not on the DVD player...I'm doing Rurouni Kenshin right now by the way. Thx for the reply, hope you can help out. msn messenger: Sheildbreaker@hotmail.com
converting OGM/MKV to AVI (with dual audio track)
By mwasim1 in forum Video ConversionReplies: 1Last Post: 4th Jan 2009, 23:54 -
FFMpeg Dual Audio MKV/OGM Non Monotone Timestamp
By blazerqb11 in forum Video ConversionReplies: 8Last Post: 25th Jul 2008, 16:36 -
Dual Audio .ogm/.mkv to dvd
By aszwet1 in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2007, 20:35 -
Dual audio .mkv/.ogm to DVD
By aszwet1 in forum Authoring (DVD)Replies: 1Last Post: 10th Jul 2007, 19:12 -
Dual Audio .OGM format to MPEG4
By Van Klizzy in forum Video ConversionReplies: 4Last Post: 30th Jun 2007, 00:50
