Hi,
Let me start by saying , if there is a guide that answers my question,
just point me to it.
I have read a few guides but they do not have enough info.
I have a AVI file (Divx) with AC3 audio.
#1. I run V-Dub and save the wave file.
#2. I use TMPGENC and I encode the file using the original video and the wave file from #1.
#3. The output MPEG 2 file , I burn to DVD (moviefactory 2).
#4. When I play the movie on my DVD player , there is no Surround sound , not even stereo.
What am I not doing.
thanks in advance
Find a program like Gold Wave, and load the video into it. It will show you what kind of audio it contains, and can also convert mono into stereo.
Hello. -
I had a problem with AC3 audio not converting right also, stumped me for over a week.
But i think I might have found a soloution..
when I tried to convert the AVI file in TMPGenc it always gave me an ACM failure, because it couldnt decompress the audio, but I found an AC3 Audio decompressor heres the link.
http://www.movieking.co.uk/guides/moonlight.html
It worked flawlessly for me, let me know if it works out for ya
good luck. -
Step one is your problem, if you convert it to a wav the 5.1 is gone. Just use DVD2AVI to extract the ac3 file then when you make you DVD use that instead of the wav... Or maybe it's virtualDUb I'm thinking of.
You won't be able to use moviefactory though cause it doesn't support ac3. You could use ifoedit to author the dvd though.
MPEG4-AVC (H264) + AC3 -> Divx + AC3?
By thomas_fogh in forum Video ConversionReplies: 12Last Post: 1st Nov 2008, 20:25 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 19:22 -
DVD to DivX w/ AC3
By MoVieBoy007 in forum DVD RippingReplies: 12Last Post: 26th Apr 2008, 23:03 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24 -
Best (easiest) DVD to (DIVX or Xvid) with 5.1 (AC3) Audio out
By balagan in forum DVD RippingReplies: 5Last Post: 11th Dec 2007, 15:16
