Ok I converted a Divx movie with TMPgnec and got this Mpeg2 file. Its a 3.2 gig file and I need to burn it to a dvd disk to play it in my standalone player. Do I need to convert this mpeg file to Vob files or can I burn it? I know all dvd movies have a Audio and Video folder with vob files in the video folder. If i can just burn the mpeg with Nero or something else?
Or will it will play in the comp this way by clicking the file, but will it au tomatically start up in a standalone this way? Help!
You need to use DVD authoring software.
You should look in the "How To" section under "How to author and burn to a compliant DVD with menus and chapters".
Good luck! -
....unless you have a standalone player that will play raw mpeg files on a data disc...
if not, yeah, you have to author.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light"
How can I Burn DVD using avi file and .srt file as subtitle
By Gayanx in forum Authoring (DVD)Replies: 7Last Post: 15th Jul 2012, 00:56 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
NTSC MPEG2 file to PAL M DVD
By Ed2009 in forum DVD RippingReplies: 2Last Post: 27th Sep 2009, 23:05 -
How to burn .pvr file to dvd please?
By Brad McGee in forum Authoring (DVD)Replies: 5Last Post: 1st Feb 2009, 21:49 -
convert hd pal mpeg2 file to hd ntsc mpeg2 file
By gearo in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 5th Jun 2008, 01:12
