Is there another program to convert .dat to mpeg besides VCD Gear? VCD Gear doesn't always work
ummmm... right click and rename the .dat to .mpg works most of the time without the wait for vcdgear to run.
Tried that, I have a VCD that plays ok on my player, but I can't convert the dat file to MPEG!!!
kre8tor,
Renaming is a bad idea -- it has been discussed many times why...
As for the time it takes for VCDGear to run, it takes no longer than COPYING the DAT file to the HDD if you use it directly on the DAT file on the VCD.
thebach, I can think of three other ways:
1. Use TMPGEnc MPEG Tools and load the dat file with the the simple multiplexor. Set the output file on the HDD. Remember to use the setting "MPEG-1 Video-CD".
2. Extract the VCD as a CUE/BIN image, then use VCDXRIP (part of the VCDImager) on the bin file.
3. Extract the VCD as a CUE/BIN image, then use VCDGear on the bin file. This should always work even if the filesystem on the VCD is broken (load the bin file as raw).
Regards.
Michael Tam
w: Morsels of Evidence -
i use isobuster to extract bin/cue files to mpg when vcdgear cant work, or there's no cue sheet, though one can easily be made.
ztr
VCD Karaoke (MPEG DAT file)- removing the vocals
By tsrusa2002 in forum Video ConversionReplies: 12Last Post: 22nd May 2011, 03:51 -
convert VCD.DAT/MPEG to RMVb with dual channel audio
By newbievideohelp in forum Video ConversionReplies: 15Last Post: 7th Nov 2008, 00:42 -
How to corp a dat or mpeg file to mpeg
By onlyrasel in forum VCDEasy GeneralReplies: 1Last Post: 27th Sep 2008, 00:18 -
Empty file when converting vcd (.dat) format to ipod (mpeg4)
By happyriceman in forum ffmpegX general discussionReplies: 3Last Post: 5th Jul 2008, 06:19 -
Problem converting audio of VCD MPEG-1 to author DVDs
By Greycat in forum Video ConversionReplies: 6Last Post: 16th Jan 2008, 17:28
