Ive got lots of svcd's and vcd's which i have burnt onto cd-r's, they will not play on this player, for the record im 100% sure it supports vcd and svcd, does anyone know wot is wrong? is it not able to read cd-r's?
Cheers
Martin
thats virtually the same player as your 119 man.
try the multi region hack and switch off the macrovision,see if that helps.
but,with past experience,it should play straight out of the box.
8) -
check out the playr hacks to the left of here in the menu..
tells ya there. 8)
Problems with Alba 108 DVD player
By Normie in forum DVD RippingReplies: 1Last Post: 13th May 2010, 12:44 -
Advice needed for Recording using Alba DVD recorder
By rhicel in forum MediaReplies: 2Last Post: 13th Mar 2008, 11:26 -
Alba dvd382stb
By djmagnifique in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Jun 2007, 18:10
