I just did a 7 VCD -> 1 DVD conversion with SVCD2DVDMPG+ but I buggered up the auth step. Although I did a new VTS for each pair of VCDs (i.e. one VTS per production - one VCD was only a single disk) I forgot to do a menu and therefore when it burns, there are no menus and only the first production plays.
Can I redo just the author step, getting the menu right this time? I can't see an obvious way to do it and I don't have the space to totally back up my work directory and the DVD directory in case it all goes wrong!
author it with dvd lab or tmpgenc author. svcd2dvdmpg+ 1.0 can only do 2 menu options. and your other vts or tracks will play you just have to skip them with the track button on your dvd.
Yf -
Hm. my dvd player will only play stuff from the first VTS , there's no way of getting it to play the other stuff. I'll check out the alternatives, thanks.
How to embed subtitles into mkv STEP BY STEP using MKVMERGE and MKVEXTRACT
By lelouch283 in forum SubtitleReplies: 30Last Post: 23rd Jun 2017, 14:04 -
MP4 X.264 to AVI XviD - Hard Sub with ssa subtitles (1 step or 2 step?)
By ssray23 in forum SubtitleReplies: 4Last Post: 29th Aug 2010, 19:35 -
Need DVD Rip Step-By-Step Instructions For Best Quality
By bht42 in forum DVD RippingReplies: 4Last Post: 26th Jul 2010, 09:28 -
The Complete Step By Step DVD Ripping/Burning Primer for Mac...?
By oliasdoug in forum MacReplies: 0Last Post: 10th Nov 2009, 07:04 -
Audacity guide for beginners, step-by-step
By AleksandrIgnatov in forum User guidesReplies: 3Last Post: 20th May 2007, 20:34
