  1. I have a Dansai 952 player, I was messing around with the video output in the menu, now all the I get on screen is a rolling picture. Is there a way to reset the player back to factory defaults with a keypress at powerup.
    or
    Can someone give me a key press list so that I can set it back to original settings blind...
    Thanks in advance....
    Big Jon
  2. All sorted now...........
    Thanks anyway!!!!!!!!!!
  3. 8) SO ? how did you fix this??
    The electronic components of the power part adopted a lot of Rubycons.
