  1. tophope
    Guest
    When i put vcd's on to a dvd-r using svcd2mpg+ the timer on the standalone dvd player doesn't work it stays on zero throughout the movie.When the source is svcd, it works fine.Anyone know why ?
    cheers
    tophope
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    I think that different players interpret the DVD-(S)VCDs differently - as they are non standard. Mine doesn't have this problem & others will have different "issues"
