I just upgraded my old AMD Athlon 900 MHz to a new P4 2,4 GHz with a 333 MHz memorybus. Correct me if I'm wrong, but shouldn't I expect an increase in encoding speed for i.e. MPEG-2?
CPU power and encode time is almost a direct inverse linear relationship.
it looks like your new comp should decrease encode time by more than half.
things to keep in mind...did you change any encode settings? filters add extra time, especially "adaptive de-interlace filters"....and motion search accuracy can add lots of time...especially if you choose "highest quality (slowest)".
also, clockspeed (Hz) means differently between AMD Athlons and Intel Pentiums...at least with the earlier ones....before Intel had 600+ Mhz FSB.
if an Athlon and Pentium were to have an exact clockspeed, Athlon will blow the Pentium away. hence, an Athlon can achieve similar CPU power with a lower clockspeed than Pentium. Again, may not be the case with current Pentiums, as new Pentiums can have that 600+ MHz FSB and other enhancements.
even so, jumping from 900 Mhz to 2.4 Ghz should be a big improvement on encode time. -
No problems, just curious as I haven't tried any encoding yet. I just bought it and was surfing on my laptop as I was re-installing windows.
Movie speeds
By drmrsolds in forum Video ConversionReplies: 8Last Post: 16th Nov 2009, 07:35 -
Write Speeds - anything new?
By Mike99 in forum MediaReplies: 22Last Post: 10th Feb 2009, 20:41 -
Burning speeds
By Rogert in forum Newbie / General discussionsReplies: 2Last Post: 1st Sep 2008, 08:28 -
Encoding speeds
By Illusionist in forum ComputerReplies: 13Last Post: 11th Jul 2008, 11:01 -
explaining copying speeds
By nobbydadog in forum Newbie / General discussionsReplies: 1Last Post: 30th Dec 2007, 04:19
I'll second that....
