Hi i am new to the world of media
and i just need to know the basics of converting VHS to AVI or MPEG
stuff like equipment needed, software needed and maybe a guide
thanking in advance
Adam
Zidane Tribal,
Best place to start is by clicking on the links to the left of this forum. There are good guides for beginners in the "How To" section. This is a pretty good place to start..
https://www.videohelp.com/articles
Have fun!
the super basic - you are going to need a capture device. You can compare notes on them in the Capture Cards section at left.
Once you have decided on a capture card, you will need capture software. If you check in the Tools section, under Capture, you will find reviews, links and descriptions. Many people like VirtualDub. I like Virtual VCR and iuVCR myself.
Your capture card and setup (and your temperment!) will determine whether you should capture in avi and convert, or capture direct to mpeg. If your hardware will support it, and if it gives you acceptable quality, there is nothing wrong with capturing to mpeg. But if your card doesn't capture to mpeg well, you may find better quality by capturing to an avi and converting to mpeg after the fact.
Poke around in the guides a bit, and when you have some more questions, come on back and post.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light"
(VHS to DVD) AVI filtering vs. straight MPEG; Post your comparisons
By darito in forum Capturing and VCRReplies: 37Last Post: 2nd Apr 2012, 04:26 -
Mpeg vs. Avi for VHS to DVD
By smartel in forum Newbie / General discussionsReplies: 4Last Post: 1st Jan 2011, 10:39 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 07:30 -
What hardware do I need to go from VHS to Mpeg (or avi)?
By RichTJ99 in forum Newbie / General discussionsReplies: 8Last Post: 26th Oct 2007, 00:54 -
Capture Software for VHS to MPEG/AVI
By quantass in forum Capturing and VCRReplies: 1Last Post: 7th Sep 2007, 14:22
