My Sony DRU510A only rips at 2x which takes far too long. I have an idea that DVD ROMS can read movies at higher speed (16x only refers to data and not movies) and I'm looking to achieve 4x or better. Anyone have any recommendations?
Results 1 to 10 of 10
try going to your hardware device manager, right click on whichever IDE channel your dvd-rom is on, and enable DMA. (properties - advanced settings)
if you have it set to PIO only, it'll take like an hour for each movie. DMA takes me 10-15 minutes.poop. -
You're right -- and the Sony can't be speeded up.
DVD burners are capped at that speed as a token node to the studios (and note that Sony is ALSO a studio, which lends extra urgency to their position). But any DVD-ROM can read *much* faster (and will save wear and tear on your burner -- two excellent reasons to get one).
I bought a Sony ROM to go along with my burner for less than $40, including shipping. It rips routinely at 8-9x: get yourself something similar."Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang -
I use a dvd-rom for ripping. its a 16x speed and ripping is based on data extraction. depending on the dvd (dvd-5 or dvd-9) using dvd dycypter i can rip at 12x for single layer and 7x for dual layer dvds. my sony drive is too slow for this.
the latter is very important, as it will be much cheaper ($30) to replace a dead DVD-ROM than DVD burner ($150+).Originally Posted by mkelley
From what I understand, only Sony DVD writers are maxed out at 2X ripping. I have a TDK 440 +/- writer and also a Pioneer 105 and both will rip at an average of 4X-5X. That's why I didn't go with the Sony writer. But of course I also use a Samsung DVD-ROM that rips at an average of 8-10X
No, my Pioneer 106 is also capped -- this was a recent development (sort of a gentlemen's agreement now that burning is common).
My el-cheapo CenDyne (cost me $10 on the weekend special) rips at a whopping 14x, and on dual layer it go at 10x. Its a 16x reader.
This is on one of my other computers that has the same specs as mine except for the DVD-ROM. -
Can you guys give your DVD-ROM model number? I bought a Samsung SD-816 for ripping. It was ripping at 3.4x for a while and now it will never go above 1.9x. I have tried the BIOS setting to enable DMA, in windows it auto selects PIO4/DMA2 but it still only rips at 1.9x max. Do I need to change a cable?
Ripping speed for dvd-r
By vcd4me in forum DVD RippingReplies: 10Last Post: 22nd Apr 2011, 06:45 -
If i ripping a DVD Movie to H264/MPEG-4.
By skorpinok in forum DVD RippingReplies: 4Last Post: 24th Aug 2010, 12:12 -
DVD Fab v/s AnyDVD Ripping Speed
By wulf109 in forum Blu-ray RippingReplies: 0Last Post: 25th Mar 2010, 14:04 -
DVD software to speed up playing a movie?
By Haopengyou in forum Software PlayingReplies: 6Last Post: 28th Aug 2009, 08:36 -
Movie-Only Ripping - full main movie shows up as more than one title
By ecc in forum DVD RippingReplies: 2Last Post: 9th May 2009, 02:13
