Hi thanx to the people who helped me with my last problem.
I have got the files off the DVDs thanx to the software like DVDShrink, but it appears that the DVDs are like 5/6gig and wont fit onto a standard 4.7 gig DVD-R. Is there anyway to compress these files so that they will fit, and they can be played on my home DVD player?
J Man
That's the whole point of software like DVDShrink -- did you not understand how it works?
You might want to go through it again (hopefully you are using version 2.3) and note that you can set levels of compression in order to get your backed up movie to fit on one disk -- you want to set those levels until you have no more red at the top. Some disks won't compress down very well, and you'd be better off either removing the extras (and DVDShrink can do this as well) or splitting them among two disks (DVDFab and DVDXCopy can do this)."Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang -
great guide for DVDshrink here: http://www.doom9.org/index.html?/mpg/dvdshrink2-main.htm
read it.
also, may wanna check out DVDshrink's official website here for more info as well: http://www.dvdshrink.org/ -
Everyone wants their hand to be held. I guess they just can't read directions in a guide a simple as DVD Shrink. Go from unknown to known please.
Sorry. Im a bit new at all this. Thanx for you help and comments, ill remember to look at the guides in the future, bit stuipd i supose, not thinking about looking at the instructions *laughs*
Thanx again
J Man
DVD Rom can burn DVDs but won't recognize burnt DVDs.
By soonie in forum DVD RippingReplies: 0Last Post: 23rd Aug 2009, 17:03 -
Newb help: Dual layer DVDs and burners, help? (files too big for standards)
By mr_goodbomb in forum Authoring (DVD)Replies: 15Last Post: 10th Jul 2008, 23:21 -
Big big troubles with firewirre PCI card.
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 1st Mar 2008, 00:51 -
Home video too big for DVD. How do I put it on 2 DVDs?
By Saaski in forum Newbie / General discussionsReplies: 12Last Post: 14th Jan 2008, 17:00 -
Too big size after join two DVDs
By ByteVV in forum Authoring (DVD)Replies: 8Last Post: 25th Sep 2007, 05:46
