  1. Hi,
    I am currently trying to put an xvid avi file to svcd with TMPGEnc. I am using the standard ntsc film template. Are these the best video quality that can be obtained? or can better be obtained using better settings?
    Cheers
    meme
  2. Member FT Shark's Avatar
    Feb 2002
    Land Down Under
    I would:
    1) Load the SuperVideoCD (NTSC).mcf
    2) Encode at constant bit rate
    3) Keep the encoding bit rate at 2520
    4) Encode as non-interlace (progressive scan)
    5) Set the motion search estimate to High Quality slow
