I am looking to convert .avi movie files with 5.1 surround onto DVD-R to watch on my TV via my standalone DVD player. I have search the forum but can't seem to find a guide that will provide the 5.1 surround on the DVD-R.
I have managed to get a movie onto a DVD-R & play through my DVD player but have not managed to keep the AC3 sound. I have a home cinema setup in my front room & the best my amp can do with the sound is PLII.![]()
I am using VirtualDub (all versions), TMPGEnc Plus, & Ulead Moviefactory2.
Any help would be much appreciated !!![]()
The thing you need to remember about AC3 sound is that once you have extracted it with Vdub, you need to run it through Besliced to remove the WAV header and fix any errors. Problems arise when you try to convert 23.976fps AC3 to PAL, Besweet just doesn't do it in a way that my player likes.
Thanks for you reply.
I have tried to use Besliced, but when I drag the .wav file over (the small picture of a man) & select ac3 I just get a notepad window open with a blank page & flashing cursor?? I have obviously done something wrong but I don't know what! Can you help? -
When you extract the AC3, change the extension to .AC3. BeSliced might be getting confused if you leave the .WAV extension on...
Still no joy with besliced
I changed the extension but it did not help. I have tried to uninstall & reinstall it hoping that it would work but still no good!
Why do I get the notepad window pop-up when I drag my audio file into the besliced window! It's driving me mad cos I think that this is the key to being able to convert an .avi movie with ac3 onto a dvd-r disk!
Please help me!!! -
If Besliced isn't working for you, then try AC3fix. You might want to read this first though...
https://www.videohelp.com/forum/viewtopic.php?t=146444
Avi to Ac3 user guide. How to encode the audio from an avi to ac3 .
By freebird73717 in forum User guidesReplies: 5Last Post: 9th Dec 2009, 21:53 -
Convert AVI with H264 and AC3 to AVI with XVid and AC3
By ashwin.terminator in forum Video ConversionReplies: 4Last Post: 26th Jul 2009, 11:17 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 19:22 -
I need a guide to convert avi to dvd plz (newbie topic) help
By Death009 in forum Newbie / General discussionsReplies: 4Last Post: 24th Oct 2007, 07:03 -
converting mpeg2/ac3 and avi/ac3 to avi/lambmp3
By corumz in forum Video ConversionReplies: 2Last Post: 17th Sep 2007, 09:32
