Can somebody help please.I had a problem last with with a file i had which i was trying to encode with tmpgenc.The problem was eventually solved with a codec file.Now i have a problem with the audio side of the file.When i try to change the compression rate witth VirtualDub i get an error message- no audio decompressor could be found to decompres the source audio format.But when i open the files with G Spot i get -The following codec should be capable MPEG Layer 3 decoder.
The files all play fine in WMP and Power DVD.
Is there something else i should install or have i un-installed something i shouldnt when messing with codecs last week
Thanks Yf,
Im afraid it hasnt helped.I d/loaded it installed it.Opened the file and tried to change the compression rate and get the error message;-
ACM failed to suggest audio decompression format.
Is there anything else i could try. -
I think its more of a codec problem that i have.Tmpegnc wont open my audio files either.So there must be something i did last week to get xvid files to work.I think ive uninstalled the wrong codec as i did try allot but as most didnt work i was uninstalling them.What i cant understand is the fact that WMP and Power DVD are still playing the files properly with the audio?.
Can anybody shed any light on this?.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 06:36 -
RipBot264 Audio Problem (no audio)
By fefalas in forum Video ConversionReplies: 9Last Post: 8th Apr 2011, 10:39 -
audio problem
By harariman in forum AudioReplies: 10Last Post: 7th Jan 2009, 21:31 -
problem with Audio
By cgguy in forum AudioReplies: 1Last Post: 14th May 2007, 06:48
