i'm trying to convert a mov file but i'm having trouble getting the audio to convert. i tried to export it with quick time pro, i tried tmpgenc and i tried RAD Video Tools. but i thin kthe audio is protected or something. i just want to make the mov into a mpg or avi with the audio. does anyone have any idea what i can do?
Some QuickTime files are protected, but you can try using EO-Video, if that doesn't help, I don't think there is much you can do.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
The only surefire way I've found to be able to do what you want was mentioned in an earlier post, a few months ago.
Like you, I could not find any programs to do this successfully, so the fix was: capture the video through whatever method you usually use, then play the mov file again and capture sound with the sound recorder program that comes with windows or your soundcard.
I needed to make the LINE IN audio the method to record.
Then you mux the video and audio together.
Good luck.
Noob convertion question
By Bob-bob-bob-bob in forum Newbie / General discussionsReplies: 4Last Post: 3rd Jan 2012, 12:14 -
mencoder wont convert the complete file, mov to avi|mov
By bjornieB in forum Video ConversionReplies: 2Last Post: 19th Nov 2009, 07:42 -
Convertion problems
By M_2008 in forum ffmpegX general discussionReplies: 2Last Post: 4th Jul 2008, 15:49 -
mp4 convertion
By ht0160 in forum Video ConversionReplies: 2Last Post: 15th Feb 2008, 01:09 -
Video convertion
By kireetkvn in forum Newbie / General discussionsReplies: 3Last Post: 10th Sep 2007, 00:50
