Here's the thing i have the movie as a divx format (.avi). I succesfully (i hope) encoded it to MPEG. Now I try to put it on my blank DVD RW, but when put it in my DVD player it doesn't play back. Maybe I'm not burning it on rite...Can I use some software that I can download to burn the file on to my DVD RW or could there be another problem or am I missing something. I used this guide for my instructions https://www.videohelp.com/tmpgencdvd.htm PLEASE HELP ME.
https://www.videohelp.com/dvdplayers
does your dvd player support DVD-RW?
also, are you simply just burning the .mpg file as is on the DVD (i.e. DATA DVD)???
you need to author the .mpg to DVD VIDEO. -
Yea I'm just burning the .mpg file raw on the the dvd. I havnt authored it. Ho do u do that?
Putting different types of file formats on to DVD-R
By carl606 in forum Newbie / General discussionsReplies: 10Last Post: 11th Mar 2010, 06:11 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
Audio problem when converting a MPEG file to AVI
By Kareng in forum AudioReplies: 1Last Post: 2nd Jul 2008, 16:56 -
problem converting one little file to mpeg MOV (any ideas why)
By bdaul in forum ffmpegX general discussionReplies: 5Last Post: 1st Jan 2008, 09:32 -
mpeg file subtitle timing problem
By ecc in forum SubtitleReplies: 5Last Post: 25th Jun 2007, 08:07
