I presently have a 16x DVD Rom Drive and a 48x24x48x CD-RW Drive. And I have a new 4x DVD+/-RW dual mode, combo CD-RW drive to install. The Read speeds on the new DVD/CD burner are slower than the present drives, so instead of replacing the present CD-RW, I'm thinking about using the new DVD burner drive in a USB2/1394 External Case Drive Enclosure. This way I can always Read from the 1st DVD Rom drive, write CD's to the 2nd CD-RW drive and write DVD's to the 3rd DVD+/-RW external drive. Will this work ok or is it better to connect directly to the IDE? I will appreciate any input.
P4, 2.4Ghz, 256MB DDR SDRAM, 60GB HD
Don't put the DVD Writer in the USB Box. If you must keep the extra CD/RW then buy an ATA Card which will give you 4 extra IDE devices. I take it you already have two hardrives installed? If you don't want to go this route then stick the CD/RW in the usb encloser. I think you'll find that you may not use it as much as you thought you would. I have the same setup and it hasn't been turned on in months. But it looks nice in it's own box.
DVD exploding inside the drive from a drive exceeding 24x. True?
By snafubaby in forum MediaReplies: 10Last Post: 5th Dec 2010, 19:05 -
how to install mp3 player in 1 gb flash drive
By sksingh in forum Newbie / General discussionsReplies: 2Last Post: 20th May 2010, 08:14 -
Cannot burn to a DVD disc and DVD RW-drive changed to CD-drive after copy
By coody in forum DVD & Blu-ray WritersReplies: 0Last Post: 13th Sep 2009, 05:18 -
Time/Date Stamp - DVD, Hard Drive, and/or flash drive camcorders
By vanjh9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 2nd Feb 2009, 19:38 -
Uninstall/Install over or Install new versions separately?
By MindF in forum ComputerReplies: 2Last Post: 5th Apr 2008, 14:43
