  1. I'm trying to capture from my DVD player using an ADVC-100. It seems that every few secounds there is a change in the signal, and the video is all strange, and then after a few secounds it switches back.
    So I decided to feed it into my VCR, and then tried it with the same thing going on. But when I watch it with the same setup on my TV it looks just fine. So what is with that??
  2. Its possible that its the Macrovision. You might be able to get a hack for your DVD player on the left side of this site.
    Mar 2002
    Milwaukee, WI USA
    If MV is the problem just hold down the input select button on the ADVC for about 20-30 seconds, MV is then disabled until you shut off the ADVC.
