I just downloaded a movie which is in a weird DivX format. Its at 14.985 frames per second, 352 by 240 pixels. I can view it fine in Windows Media Player, but when i try to convert it in TMPGEnc the preview it completely black. The result is a file that has the sound, but no picture. whats going on? another question, will the result on vcd be extremely crappy and un-watchable?
Sounds like a new Mpeg4, super compressed
, takes a lot of time to uncompress and display those. Click right mouse select properties on AVI, see what it says.
Is it a full movie, but only around 150Mb ?
yeah, its mpeg4 V3 or something. its 170megs, 1 hour long. how can i make it into an mpeg then?
well, ive used vdub to convert it to avi, from there i can successfully convert to mpeg. the only thing that sucks is that it jitters, and i think thats because the original is in 14.985 frames per sec and i have it converting to 29.97 on tmpgenc, which is the only thing i can do right? otherwise it wont play as a vcd on my dvd player?
You can also frameserve it to TMPGenc w/ AVISynth (this is what I normally do).
Yes those Mpeg4's are ok to play, but unless the original convertion had a good quality movie to work with, they are not so good.
I also re-save to DivX fast motion, then they are much easier to work with. You have done as best as you can considering the original source is not so good.
DVD to an edited MPEG-2 file with MPEG audio: Trouble/please help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 21Last Post: 9th Aug 2011, 09:52 -
Trouble Converting TS to MPEG
By Somebody2 in forum Video ConversionReplies: 2Last Post: 14th Jul 2010, 19:30 -
trouble burning MPEG to DVD
By desert_dick in forum Authoring (DVD)Replies: 1Last Post: 19th Aug 2009, 15:22 -
Trouble transferring VOB to Mpeg
By Idlehanz in forum Newbie / General discussionsReplies: 8Last Post: 12th Aug 2009, 04:09 -
Trouble Finding Bitrate for DivX Xvid for CD-r
By 4194 in forum DVD RippingReplies: 9Last Post: 24th Aug 2007, 11:41
