Installed the Ace MegaCodec pack, now premier no longer works. I uninstalled the codecpack, and reinstalled premier. Premier still crashes
on program load. Anyone have experience with this?
TIA...
Joachim2311
I've had a similar problem when I installed out Vegas Video 4, it created problems with Premiere 6.5. Lukily I use Norton Ghost, and had a Ghost image taken before the Vegas install. That Ghost image got me back to normal in 15 min.
You may have to format and re-install Windows. Once you get it working like you want, You should use Norton Ghost to make a backup Image of your system. You can use that image the next time (there will always be a next time) you get into trouble.
Good Luck!Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Funny u should mention that. I do have a Ghost image from my last fresh install, so that's always an option.
Thanks for the replyJoachim2311 -
UPDATE:
I reinstalled the Ace Mega Codec pack. Premier now loads normally.
Just FYI for the next poor chap who has the problem.Joachim2311
First tests regarding ACE Advanced Convertor Enhancer
By SatStorm in forum RestorationReplies: 18Last Post: 15th Mar 2022, 15:17 -
Issue with LCD and turning off ACE
By silverforte in forum DVB / IPTVReplies: 0Last Post: 22nd Mar 2010, 00:39 -
M2TS to Premier
By Mylriahd in forum Video ConversionReplies: 24Last Post: 6th Mar 2008, 10:17 -
Ace Combat 6 Anime/Manga Chicks!
By retroborg in forum Off topicReplies: 3Last Post: 4th Jan 2008, 01:13 -
Looking for a ACE Enhancer converter
By durieux in forum RestorationReplies: 0Last Post: 8th May 2007, 15:14
