  1. Hi, I hope someone out there can please help a frustrated novice ...
    I have recenlty installed vcd easy and find it impossible to burn a vcd with it ... combined with nero. It says force driver in the cd/writer/reader. My cd burner is a sony crx2151 e1/sys2.
    This follows a message CDRDAO WRITE EXECUTION FAILED
    FORCE DRIVER If you are sure your disc is empty (which it is, a new one) then you may have to force driver in the cdwriter/reader settings page.
    I have tried this but get completely frustrated on how to sort this ....
    PLEASE help me !
    Many thanks, Dave
    Jul 2003
    Ontario, Canada
    You can use VCDEasy to burn your VCD or SVCD. If you have installed Adaptec ASPI 4.6, you can choose your Sony CD writer to burn. You have to set it as "raw" driver in the setting menu.
    Hope the above helps.
    Sam Ontario
