I am a pro at ripping DVD to SVCD with spectacular quality but new to video camera film work. I have learned in this forum if i take my DV and convert it to Mpeg2 and then multiply it by pie re-encode it to divx then devide it by 32 re-encode it to something else cut edit ad titlels burn and reboot pc im in luck. My question is, WHAT effective and simple program is there to select scenes in my home video and SIMPLY delete THEM REDUCING THE FAT in my video. I have tried video studio and moviefactory and windows movie maker and TMPGE, all seem rather complicated to just cut unwanted Vid. Anyone been where I'm at? HELP.
I have read and read but must not of hit the right messages or help files.
Step #1
Capture the DV via firewire to your computer. This program should be simple. It will split the video up into seperate files based upon your tape time stamps.
Step #2
Cut or Join what you want. Look at the virtualDub or Avisynth guides under How to Edit to the left. VirtualDub maybe more clear. Avisynth is quite simple to use but seems strange at first. [It has no gui and runs off of scripts. A join command would be like AviSource(file1) ++ AviSource(file2) ].
Step #3
Encode your result to MPEG2
Step #4
Author to DVD
Hope this helps. You can get lost in the details of any of those steps, but the process can be quick and painless. -
I like Pinnacle Studio 8 (when it works). It is easy to use. At least for me
Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
Thank you both for your replies. prior to reading your posts I went back to TMPGE as this is what I use when encodeing ripped DVD's and realized that clipping unwanted footage was very simple with TMPGE (just missed it first 5 times round ). I am 80 percent through a encoding to mpeg2 and will burn to SVCD to see if I have achieved the quality I'm hoping for.
If this fails (quality) I will try your sugestions.
Duke107
Simple cut on .mov file
By ranchhand in forum EditingReplies: 2Last Post: 20th May 2011, 09:26 -
Looking for simple software to cut mpeg1 into many pieces in one step
By jimdagys in forum EditingReplies: 11Last Post: 6th Jun 2009, 04:35 -
Final cut express simple question
By thecrock in forum MacReplies: 1Last Post: 17th Apr 2009, 10:48 -
Simple way to edit MiniDV footage and save it to DVD
By jellyfear in forum Newbie / General discussionsReplies: 3Last Post: 13th Apr 2008, 17:35 -
Best simple software for HDTV camera footage to H264 PS3 format
By lneves in forum Video ConversionReplies: 34Last Post: 27th Jan 2008, 14:13
