hi,,
i started to use restream to change the fps of a
svcd.but it causes blockyness.mainly if theres
left or right movement in the picture.its fast
if you want to change fps or the resolution.
i also change the resolution from 480x480
to 352x480.
you can find it here.
http://shh.dvdboard.de
thanks.
Hi Nednedned,
I used a program from Dynapel called motion perfect for converting avi's from 23 to 29.97, but it only works on avi's. It even fixes dropped frames. But I did not ask what type of video you were trying to convert (avi,mpeg,mjpeg..) Sorry -
it an svcd.mpg,seems mainly to happen on the right hand side
of the screen.like the screen is being pulled. when the camera
moves to the left.its a pitty as the program solves problems
for me.i demultiplex with tmpge.but it wont let use the .m2v
file.to change the framrate.as i want to put it on dvd.and dvdlab
wont allow 23fps. -
Why use re-stream?? just use pulldown.exe. you'll like the results and it's fast + you can change other flags in an mpeg2 stream as well
http://www.digital-digest.com/dvd/downloads/pulldown_gui.html"The software said Win XP or better, so I Installed Linux" -
as lpn1160 sez....add the 3:2 pulldown flag to your .mpg so that it will be played back as 29.97 fps...even though it was encoded as 23.976 fps...
this is much easier...no converting/re-encoding necessary
restream a live stream
By nerojan in forum Capturing and VCRReplies: 2Last Post: 4th Jun 2016, 12:29 -
How to restream mms link?
By Neil_2004 in forum Video Streaming DownloadingReplies: 10Last Post: 2nd Feb 2010, 09:45 -
ReStream
By montgal in forum Newbie / General discussionsReplies: 3Last Post: 5th Nov 2009, 12:18 -
Changing AVI from 29fps to 25fps
By Ric76 in forum Video ConversionReplies: 11Last Post: 22nd Jul 2009, 14:12 -
Restream question
By Ennio in forum Newbie / General discussionsReplies: 0Last Post: 26th Oct 2007, 14:33
